Good day,
I'm importing corridor datum surfaces from C3D to TBC via LandXML. Sometimes we need to adjust these corridor datum surfaces in TBC, and have arrived at the following:
- When exporting from C3D (2019) LandXML Surface Export Settings indicate "points and faces"
- When importing LandXML Surface to TBC the Point/Breakline-based definition option needs to be selected to allow editing of the surface in TBC
Are these assumptions correct?
Finally, the appearance of the LandXML Import Conflicts dialog appears to be inconsistent. Sometimes I'm presented with this option and sometimes the LandXML Import Conflicts dialog box does not appear.
Does anyone have any ideas here? If a surface (imported via XML) is not editable in TBC (deleting edge lines etc.) do I export/import from/back to TBC again?
Thanks!
Andrew
Andrew Walther
