Error In Loading LAS Point Cloud Files
  • 1.  Error In Loading LAS Point Cloud Files
    Posted 04-15-2021 06:21
      |   view attached
    I tried to upload a LAS Point Cloud Files into TBC for further processing.
    The file was successfully loaded but there're no point clouds data showing in TBC, instead just an icon of a scanner. All layers at filter manager were ticked up to be shown in TBC.
    Please advise me if there's any solution to fix this up.
    Thanks!
    Regards,
    Edward
    Edward Lau
  • 2.  RE: Error In Loading LAS Point Cloud Files
    Posted 04-19-2021 17:18
    Hey Edward,
    Could you provide the LAS file you're having this issue with.
    Regards,
    Shane Lyons
    Shane Lyons
  • 3.  RE: Error In Loading LAS Point Cloud Files
    Posted 04-22-2021 00:33
    Are you running a second monitor off a laptop? Disconnect and try again using TBC on Laptop screen. Have experienced similar issues with external monitors using generic port/driver and not dedicated graphics engine, particularly through a Docking station.
    Rob Davidson
  • 4.  RE: Error In Loading LAS Point Cloud Files
    Posted 12-02-2021 08:12
    Has a solution been found for this issue?
    Brandon McCreery
  • 5.  RE: Error In Loading LAS Point Cloud Files
    Posted 12-17-2021 13:33
    Hey Edward,
    Did you find a solution to this issue? I didn't see any LAS files come through. If you are still having the same issue could you please provide the LAS files for review.
    Shane Lyons
