John
I will post a video on this shortly that I did a while back - we are preparing a training course for Feb on this currently which will update the materials - however hopefully this should assist you I hope.
To do what you want you will need a good Metric Template set up to do Plan and Profile Sheets but if you do not need the profiles then you can do Plan Only Sheets in the same way. The Plan and Profile method automatically lays out the sheets for you and computes the rotations etc. of the sheets to make them fit a curvilinear alignment.
Alan Sharp
alan.sharp@rockpilesolutions.com------------------------------
Sent: 12-29-2020 14:14
Subject: Creating Corridor Plots
Can anyone direct me to where I can find training/info on how to create and plot Plans along a corridor?
I have a 20 kilometre stretch of Railway line with As Built Services (a long narrow "snaking" corridor) that I want to create plots along - I can do individual plots but not a set that encompasses the whole lot (about 30 sheets)
Thanks,
John
John Mill
