We released a new
Penmap for Android 11.4.0.2140 with the following features:
Enhancements / Changes
- Migration of "My Penmap" folder
The migration will be started on the first launch of version 11.4.0 or higher and is mandatory. Due to security restrictions implemented in Android 11,
it is no longer allowed to install or access the storage outside of the Penmap application folder.
The application folder is now located inside "Internal storage\Android\data\" for all devices.
These changes will be mandatory for all Google Play Store apps beginning November 2021.
Please note that after this migration, if you uninstall Penmap for Android from the device, all Penmap projects and settings will also be deleted from the device.
- Add suggestions for GIS fields
Penmap remembers your last entries in GIS fields and suggests them the next time you call the same GIS dialog. This makes it easier and faster to enter GIS data.
- Add controls for + / - zoom to map view
Penmap map view now has two zoom buttons that make it easier for tablet and pen users to zoom in and out. The function can be enabled / disabled in the Display menu with "Controls for Zoom".
- Add GNSS Autoscroll function to map view
Penmap map view now has a button for faster activate / deactivate the GNSS autoscroll function. The function can be enabled / disabled in the Display menu with "Controls for Zoom".
The compass in the map view has been moved and redesigned for better usability
- Add customizable appearance of the Buttonbar
To simplify the use of Penmap even more, the functions of the button bar can now be hidden. With the customized buttonbar the user has even faster access to needed tools and unused tools not visible.
The settings can be set under Settings / General / Buttonbar.
- Redesign UI Relationship handling
The relationships between GIS tables can now be edited and registered even better.
- Update Trimble Geodetic library
Bug fixes
Fixed: Unsaved relationships have not worked
Fixed: GNSS Cursor flickering sometimes
Fixed: Changing layer colors could cause a app crash
Fixed: Move node should provide a GNSS point if measured with GNSS
Minor bug fixes
Markus Koper
