Trimble Penmap
Compass Calibrtaion Android / Penmap Site calibration
  • 1.  Compass Calibrtaion Android / Penmap Site calibration
    Posted 05-03-2021 08:36
    I am posting these two issues together as perhaps they are related….
    I have Penmap Version 11.1.0.1876 TPSDK 2020.2.18.20718 installed on an Android Tablet.
    Galaxy Tab s5e SM- T720
    1. Almost every time I use the tablet with Penmap I have to recalibrate the internal compass, the internal compass works with Google Maps and Teraflex just not Penmap. When I say it does not work, I mean it does not know where I am when I start Penmap or even after I start the GNSS in Penmap, when I push the little compass icon in the upper left corner it does not center on the actual location, it could easily be 50 km away. (That is with or without Wifi.)
    I have tried moving my Android in a figure 8 but never have felt the vibration that one should feel when it is complete, perhaps that is because it is not uncalibrated. Although I get a message in Penmap saying something like for a better user experience I should calibrate.
    The bellow is what was recommended.
    1
    You can calibrate the compass by mowing the phone like painting a imaginary 8. It should give a short vibration when finished.
    2. You can switch on/off  the compass by long press on  the compass symbol in the map.
    3. As long as GNSS has not been started in Penmap, there will be no position at all. You need to press the GNSS symbol at the bottom to start GNSS. You need to see the connecting message.
    The symbol with the number of SVs needs to switch from red to green:
    Question 2.
    My points read with a precession subscription are 1.6 meters away from confirmed site points. I am working in a local coordinate system and about 30 km away from the edge of the zone, it was suggested this could be the problem.
    Do I just add some points like .dxf in the Penmap Project manager when making the project and navigate to them using the site calibration option within the GNSS method area? I tried to do this using point I had collected, and it said they were the wrong kind of "Nodes" I have a PDF from Trimble with great information, it is just not so specific as to what I need as a Node to navigate to. I have about a 2 cm accuracy and have used a tripod to take the points.
    Thanks in advance for any feedback.
    Patrick
    Patrick de Jourdan
  • 2.  RE: Compass Calibrtaion Android / Penmap Site calibration
    Posted 05-05-2021 00:48
    Dear Patrick de Jourdan,
    this seems like a topic where we need more detailed information.
    I will get in touch with you.
    Kind regards
    Patrik Stahlhut
    Patrik Stahlhut
  • 3.  RE: Compass Calibrtaion Android / Penmap Site calibration
    Posted 05-06-2021 03:44
    Following
    Denis Snauwaert
  • 4.  RE: Compass Calibrtaion Android / Penmap Site calibration
    Posted 05-07-2021 01:24
    Hi Patrick,
    Just as a clarification, I am a little bit confused by your post.
    Compass and GNSS are different functions.
    • Compass = Compass in Penmap Android rotates the map in the direction of movement, regard magnetic North
      • Also bearing / orientation can be stored in photos taken with Penmap or used for staking out directions.
      • To work as geodetic as possible we recommend to calibrate the compass. Penmap map rotation works also without calibration, but with lower accuracy.
      • If you start Penmap project and do not press the compass icon, Penmap project is oriented to map north.
    • GNSS-Cursor = Shows antenna position in the map regarding the CRS in the Penmap project.
      • If you create a Project with data in North America and "tap and hold" in the Penmap project for "zoom all" function -> Penmap will zoom to imported data and show data in North America.
      • If you are in reality in Europe and activate you antenna in Europe -> Penmap GNSS-Cursor will show your real antenna position in Europe (regarding the CRS of the Penmap project!)
      • If you have no data imported and start a empty Project, Penmap will show the region of your last project untill you activate GNSS. Then the cursor will show real position.
      • Please activate "GNSS autoscoll" function!
    Markus
    Markus Koper
