We have two cities where over 50% of our work is done in and I created a template for one these cities. I have the published coordinates for the city monuments and the network base in a job template for one of these cities. Before using SYNC we had custom templates the field could choose from to create their JOB. Now we have to drag in all the templates that might be used and give
The few templates we do use are done because of location.
The typically only have established control and the local network base in the JOT as embedded points.
The surveyor would only run a network adjustment and possibly a level loop adjustment after the fieldwork was completed.
I don't see any value on highlighting differences between the job and the project.
I am getting push back from others in my office about using SYNC for different reasons, but one of them is the speed to create a Project & job for the field. If we could automatically assign a team when a project is created then we could let the field crew create their own projects and jobs. As of now the field can create a project, but only he has access to it until he adds team members.
Tex Barnett
Sent: 11-21-2021 14:10
Subject: Where do you save a Trimble SYNC Manager the new job templates for projects?
Hello Tex,
The system is currently limited to manual drag and drop when adding templates to a project.
Enabling selection from a list of organizational resources which are available whenever creating a project is something that makes a lot of sense to me so could you answer the following questions for me?
For yourself, is a project template typically an organizational thing, used throughout your company, or location, contract or a personal thing?
What information would you typically include in your templates?
CRS definition
Embedded points
Active map files
Linked files
To what extent would you expect the surveyor to adjust from the template settings after creating a job?
Do you see any value in Trimble Sync Manager or Trimble Access highlighting that a job is using a different setup from the "project template"
Chay
Chay Froggatt
Sent: 11-19-2021 08:29
Is there a path where you can save an Access job template so when you create a new project on Trimble Sync Manager it will already be accessible? Currently I have to create a new project, then go to properties => Template, then drag and drop my template. I would like to have the templates automatically load up when a project is created.
Tex Barnett
