The displayed thresholds in the documentation are for horizontal only. We don't use vertical for this estimate
Sent: 01-04-2021 04:18
Subject: Trimble Mobile Manager accuracy thresholds
Hi Tom,
please these thresholds are same for horizontal and vertical accuracy ?
Trimble Catalyst SDK returns H (horizontal) and V (vertical) accuracy, but e.g. Trimble Mobile Manager displays to user only one accuracy value. My question is - how are vertical and horizontal accuracy combined into one value ?
Thanks
Peter Kucera
Sent: 12-22-2020 08:39
Hi Peter
This already exists in the TPSDK documentation and TPSK help files @Nico Becke will be able to help you with this
In the meantime I've copied the accuracy threshold data for you below (accuracies stated in metres)
| Precision/OD Subscription | Decimeter Subscription | Submeter Subscription | Meter Subscription |
Best Accuracy | 0.01 | 0.1 | 0.3 | 1 |
Good Accuracy Threshold | 0.05 | 0.15 | 0.9 | 1.1 |
Bad Accuracy Threshold | 0.5 | 0.6 | 1 | 1.5 |
Tom Harrison
Sent: 12-21-2020 05:18
Hi all,
Trimble Mobile Manager (TMM) can automatically detect what is expected accuracy per given Trimble subscription / fix type(RTK, SBAS, differential, etc ...) and then show the user following view, that indicates if the expected accuracy is currently met (in real time):
Examples of TMM accuracy view:
My question is - could you please provide us some document/ resource that captures these thresholds? We would like to add to our app similar view that indicates if expected accuracy is met (while using Trimble Catalyst) but to do that we need to know threshold values for every subscription/fix type etc.
Thanks & Regards
Peter Kucera
Peter Kucera
