@Tom Harrison unless I missed it I don't see anywhere on the latest release notes (January 6, 2021) any reference to the TDC600.53.80.53 build number. In fact, the OS download zip file itself doesn't have the build number in it's name.
As an example of what I think is good documentation are the 7x OS updates release notes, they have the build number in the title as well as in the document itself. And, in the earlier release notes it even stated how to find which version you have on the device.
Matthew King
Sent: 09-02-2021 07:25
Subject: How to tell current OS on TDC600
Good suggestion Matthew, I'll pass it on.
Typically we will ALWAYS reference the latest build in the release notes or bulletins that guide you how to perform these updates as in this case, the Support Bulletin: Operating System Upgrade Procedure for TDC600 does reference and link to the latest update only
Tom Harrison
Sent: 08-30-2021 06:51
Thanks @Tom Harrison! That then leads me to another question, where in the OS Upgrade documentation can you find the build number? I've looked and can't find it.
Since you're with Trimble, then would you mind passing on the suggestion that the OS documentation state the build number and then how to find it on the device itself (like how you just did). You need both information in order for it to be useful.
Thanks!
Matthew King
Sent: 08-26-2021 08:12
Hi Matthew
You can find this out via the BUILD NUMBER
- Navigate to SETTINGS > SYSTEM > ABOUT PHONE > BUILD NUMBER
- The latest OS build Number = TDC600.53.80.53
If your device displays something different then you are on an earlier OS version and should update
Tom Harrison
Sent: 08-23-2021 07:22
Thanks Bill for the response. I do know about that screen to see which version of Android is on the 600, but I'm specifically talking about which version of the Trimble OS Update is on the unit. See screenshot below for the OS Updates Trimble has released. I believe regardless of the Trimble OS Update, it's always going to be Android 8.
Matthew King
Sent: 08-23-2021 07:00
Matthew,
You will see the Android version in Settings>System>About Phone
Bill
Bill Staggs
Sent: 08-20-2021 11:22
I see that there was an OS update for the TDC600 back in Jan 2021,and that got me wondering how to I tell on the 600 which OS update am I currently using. I've poked around in the About Phone area in Settings, but I can't seem to relate what I'm seeing in there to the OS Updates that are on Trimble's website. Thanks!
Matthew King
