Hi Dave
You'll need to create a template for each data layer you import - we can't associate to existing templates at the momentWhen you import a dataset, If you want to create a ToDo for editing/ inspection purposes you will need to create a template for the imported data layers first
You will probably see the ADD option next to your imported layers like this...
If you
SELECT ADD you can define the template fields then use the form builder to
Edit the template propertiesNext publish the form and as soon as you have done this you can start to
create tasks for data maintenance workflows -
note you will need a Terraflex Advanced subscription for data update/maintenance------------------------------
Tom Harrison
Sent: 01-13-2022 23:02
Subject: Why wont a template associate with this data when uploaded?
Frustratingly I cant make a Todo for the points in this file as when uploaded there is no ability to associate a template with it
Dave Humphreys
