Hello
We have a new DA1 Catalyst with new Samsung android devices.
I have noticed a issue on our android devices where the TMM Mock Location is not allways getting pushed to ESRI collector or Fieldmaps.
I am unsure what is causing the problem , weather its the Samsung hardware or the software ( TMM vs ESRI Collector/Fieldmaps)
Its like even though the TMM is set as the mock location app, the integrate GPS is still working in the background and taking priority.
Here are some possible work arounds I have found, with varying success:
1)When using the Collector/Field maps app refresh the GPS location
2)you can sometimes get the TMM mock location to come back by checking the location provider setting in ESRI apps.
Also the GPS metadata in ESRI collector sometimes grabs the wrong GPS device name.
Anyone experiencing the same problems or have a solution?
Thanks
Matthew Criel
