Hi Aaron,
the license/ subscription gets refreshed with every login and every now and then if TMM is running - so we refresh the license in the background automatically.
Every time we download a file from the server it has fresh 30 days - its basically the timestamp of the file/ when the file was loaded from the server.
In theory it should be totally fine to log in once on a Monday morning - afterwards you can work multiple weeks without the need of a login.
The typical trouble maker cases are if the phone tells us it has an internet connection - but the connection is so slow that the license refresh time-outs. Then you may get in a state as described.
If the phone has no SIM at all it gets weird - then it could be an issue introduced on our side recently.
So it would be great if you could shoot us a log - that should shed some light one this. If you already did so - I don't see those emails directly... But I'll take a look around.
And I'll see that I do some tests on iOS here - if I can reproduce the issue.
Nico
Nico Becke
Sent: 04-29-2021 05:12
Subject: Mobile Manager- Offline issues
Hi Nico- We're running 2.8.0.967 on iOS. We are working completely offline. Our iOS devices do not have cellular SIM cards, so only have online connectivity in the office on wifi.
Does the 30 days reset every time you sign in while connected, or does it only re-cache when the 30 days are up? I'm looking at a workaround where we open the app to sign in before leaving the office every day, but if it only re-caches at the 30 day mark that won't do any good. We work in rural Vermont, where connectivity is often non-existent, even if our devices support it. Having to sign-in at random unannounced times is a major issue.
By way of troubleshooting I have confirmed that as soon as we get back to wifi range, we're able to sign in and everything works again.
Aaron Worthley
Sent: 04-28-2021 23:54
Hi Aaron,
technically TMM caches the downloaded subscription files and is happy with that file for 30 days.
Can you take a look at the version number you're using - just to be on the same page. It should be TMM 2.8 as of the date of this reply.
Also are you working completely offline or is the network just shaky? If the phone has some sort of internet (slow) TMM might be able to get a reply from the server - but the actual loading of the page fails/ takes forever. Switching the phone into flight mode or turning off data would fix this problem or at least nail it down to an unstable network.
As a last comment it would also be helpful if you could shoot the TMM log file (via 'About' and 'Send log') to the default support email. The log gives us some insight on what and why things go wrong. It may contain something useful.
Nico
Nico Becke
Sent: 04-28-2021 10:28
We're using Trimble Mobile Manager configured with ESRI's Field Maps app to connect to an R2 receiver. At random times, the Mobile Manager app freezes on the sign-in page when we don't have an internet connection in the field. When that happens, we're unable to collect data in an offline setting. This is a HUGE problem- our work is always conducted offline, often hours from the office. How can we configure the Mobile Manager app to stay signed in or bypass this requirement?
Aaron Worthley
