Hi David
The TDC600 is a much more powerful unit compared to the TDC100
(Octa core from quad core cpu/ double the RAM/ x4 memory). It also runs Android 10* as opposed to Android v5.1 (later 6.0) so I would expect any issues related to hardware performance would not be a problem.
I've copied the datasheets below so you can compare the specs in detail:
Out of curiosity I googled around this issue and
keyboard 'lag' appears to be a fairly popular Android issue with earlier OS versions such as 5.1. One of the more common 'hacks' can be found
here which is referenced throughout various blogs/ articles as being a successful fix
* Earlier models of the TDC600 operate on Android 8------------------------------
Tom Harrison
Sent: 12-20-2021 11:35
Subject: TDC600 keyboard typing speed
Anyone who ever used a TDC100 knows how glacial the typing responsiveness is, even with third party keyboard apps. My question is: is the TDC600 any better?
David Greenberger
