i havent set this up in positions before, but the steps below will get you on the right track.
Open Esri ArcMap
Go into Trimble Positions Desktop Admin tool
Choose processing profiles
click on create
under search for a base station, check box next to "using a single base station" and choose select
click on NEw (you may have to select a base station to activate the "new" button
Go through the tabs and fill out the necessary information
- reference position (this can be from a known control point that you set the base on or by logging a static session and sending that file off to OPUS or Trimble Centerpoint)
- make sure that you enter/pick the correct datum
Internet server tab, nav file format
- THis is where you will setup the base file information. Since this is a local base, you will choose "base data is found in local or network drives" and browse to the files.
I currently dont have any data to test, so this is where i will have to leave off and hopefully someone else can chime in.
eric bock
Sent: 03-19-2021 05:33
Subject: Using R8 as a base station for post-processing R2 data in Positions
It has been suggested that an R8 can be used as a local base station for post-processing R2 data in the Positions extension in ArcMAP where the existing base stations are too distant. We haven't been able to identify the workflow to make this happen. Probably overlooking something obvious. Can someone point us to the proper documentation.
William Limp
