It looks like you may be confusing two different platforms with different licencing types here.
The top 'Terraflex Advanced' screen shows Trimble Insphere which is a platform in its End of Life as we transition all Terraflex users over to
Trimble Connect
- You're describing Trimble Connect so you should have received some subscriptions from your local Trimble reseller
- That you activate and assign to a user in your Licence Manager
- That allows that user to work In Terraflex on the Connect platform
Please refer to the
Licence Manager online help for a guide on this tool If you are unfamiliar and the
Terraflex Online Getting Started material
If you are having issues here then you should get in touch with your
local Trimble reseller who will be able to guide you through the setup or escalate this to Trimble support for a swift resolution for you
Tom Harrison
Sent: 06-02-2021 22:42
Subject: Terraflex licences not found in trimble account.
samwoo tech
