View Points in TBC
  • 1.  View Points in TBC
    Posted 04-19-2022 13:02
    When I create points or import points, I can not view them in my plan view or 3D view.  They are listed under the project explorer and the layers the points are assigned to are turned on.  Why can I not see my points?
    Ryne Gibson
  • 2.  RE: View Points in TBC
    Hello Ryne
    I'm going to make a 99 percent guess it is your view filter.  Can you try the ALL view filter?  See if they are in that view.
    Scott Bridges
  • 3.  RE: View Points in TBC
    Posted 04-19-2022 18:43
    Under "Layer Group" "Rawdata" you also need to enable "Point" or "As-Set Out point".
    If you are missing "Raw Data" in that list.
  • 4.  RE: View Points in TBC
    Posted 04-20-2022 06:29
    I should have maybe stated this before, I have created a layer called 'Existing Spot Elevations', which is where I want my points to be.  I have gone through the Advanced Filter Settings and everything is checked visible.   Again, I can see them when the "All" View Filter is selected, but not when my "Existing" View Filter is selected.  Can you not create a new 'points' Layer?
    Ryne Gibson
  • 5.  RE: View Points in TBC
    Posted 04-20-2022 06:21
    Also make sure show disconnected points is checked under point.
    Erik Petersen
