I've had a quick search, but hopefully someone can assist here.
We received a CSV dataset for a site, with new survey control points.
We imported the csv via (Import > Import Format Editor) and selecting (P,E,N,elev,Code (Control).
Having been to site, speaking to the surveyor, and having seen some of the marks, I would like to change some of the control to survey standard (due to capture method, site construction works, etc).
Anyway, is there a quick method to change a point from showing as control standard to make it a point?
We've removed it from the control points, but want to change its appearance.
I've looked via point spreadsheet,
I've changed it via feature code, however it still retains he triangle, as it's still control accuracy.
it's not an option on the properties - that I can see.
Any thoughts, or help would be great!
Guess an option is to remove it from that CSV file
Cheers,
Julius
Julius Newman
