Hello Andrew,
TBC 3.03 is pretty old, we are at 5.40 by now, so it might just be a limitation of that old version.
If you use Trimble Access, or even the old Survey Controller, and you export the data as JXL, you can see the time stamp for every single observation.
With the ASCII file generator and the right style sheet you can export pretty much everything from the JXL/JOB file. Unfortunately I haven't one with the time at the ready right now.
Sent: 03-22-2021 13:49
Subject: Time point was surveyed.
I can only get the following with TBC 3.03
I can get time data as long as the point was surveyed with GNSS . If it's any of the Trimble S series instruments, then no time stamp info is available.
Just looking at the same data on the survey controller – no time information is available for any of the points.
I don't think it's possible to time stamp individual surveyed points from any of the S series instruments.
Andrew Newmarch
Sent: 03-22-2021 12:26
If you are looking at the data in TBC, look a the observation rather than the point. Under Observed data in properties there should be a Time stamp field. Here is some data from a VX:
James McWha
Sent: 03-22-2021 10:50
Hi Jody ,
I had another look. if the point was from GNSS they you can pull out the time . If its from a conventional Trimble instrument then this info is not available. I remember trying to do this about 10 years ago. Was hoping this would have been fixed by now.
Andrew Newmarch
Sent: 03-22-2021 09:47
Not sure if/how you can export the time surveyed however if you go into Point Manager and scroll to the right, it should say the date and time it was measured.
Jody Savage
Sent: 03-22-2021 09:25
Anybody know how to export the time that points were surveyed. I used my Trimble S3 and now its important to know the hour/min/sec that the point was surveyed.
Andrew Newmarch
