I wouldn't trust those surface areas in the surface info report.
On a test I run it seems that the areas are delta values to the previous slice.
In this example the area for the polylines should get bigger the higher I go. In the report they are all different, but added together the give me the area of the highest line.
What you can do to verify the areas is to set the property "Drape surface" of the Isopach to "no", create Contourlines on the Isopach, explode those and check the stringline area in the properties pane.
Sent: 07-14-2021 15:46
Subject: Volume in specified depth area - ist it possible and if it ism how to do it?
Frederick,
I have never had a problem with Earthworks Report.
How are you calculating your Area By Depth?
You are looking at area by depth on the Cut/Fill Map surface, or is it ISOPATH surface?
Marian Plucinski
Sent: 07-14-2021 01:03
That will not give me the correct volume, i dont really know how that function works but it gives me the wrong numbers. look at the picture below. As you can see i have only 479m2 surface (the picture above) wich is 1m or lower to excavate and if i do the same volume report as i did for the cut n fill and choose "by depth increasement" it will sa that i have 622m3 in volume. Thats more than 1m on that surface. So i need some other way.
Fredrik Bergstrom
Sent: 07-14-2021 00:31
Surface -> Earthworks Report -> Volume Breakdown by depth Increment
Marian Plucinski
Sent: 07-13-2021 23:20
Hi there!
I have a surface and i want to report this surface like this (the bold text i dont know how to do):
- Total volume - surface to surface
- What is the area where the excavation is 0 to 1m - surface area report of the isopach.
- The volume of the excavation 0-1m - i dont know how to do this in a easy way.
One way to do that volume calculation is to do create contours on the isopach on 0 elevation and -1m elevation and use thoose lines as boundarys in a volume calculation but that is a lot of work and i wonder if someone has a workflow wich is easier.
Have a nice day!
Fredrik Bergstrom
