We've seen some conversion issues with user defined coordinate systems.
We found an issue happening if the project is created with Penmap for Android version 11.1.0.1825.
After the project is done and the export button is pressed there is an error message mention that the "
User defined coordinate system missing:".
We are working on this.
Projects created via Penmap Project Manager are not affected.
Workaround to export data
If you need to get your data exported from existing projects now:
- Download the pdt
- create a new project via Penmap Project Manager
- use the same template and coordinate system as you had in the project
- select the pdt for import (needs to set the format selection to "All Files (*.*)"
- Download the project to Penmap for Android
- Open the project
- Close/Save the new project
- Upload to Cloud
- Export
Cornelia Schmitz
