WorksManager
Project Boundary - PLEASE REMOVE IT
  • 1.  Project Boundary - PLEASE REMOVE IT
    Posted 09-20-2026 15:50
    Please get rid of the project boundary all together for project setup. It's such a waste of time and annoyance to go to the site and draw out the boundary. I try to import boundary lines and that rarely works. Sometimes we have phases of sites and boundaries can't touch other site boundaries. The whole feature is just useless and makes creating projects really difficult.
    David Spegal
  • 2.  RE: Project Boundary - PLEASE REMOVE IT
    Posted 09-22-2026 19:25
    Hi David,
    We usually just create a generic boundary, large enough that we know 100% this will cover the job (and not cross into another project's boundary). Then, within 5 minutes, we replace the boundary with one from TBC, that will be more accurate to the actual limits of the site.
    Allan Rundell
  • 3.  RE: Project Boundary - PLEASE REMOVE IT
    Posted 09-23-2026 00:31
    Hello David,
    Thanks for sharing your feedback. We will get in touch with you to learn more about this and make this process smoother.
    Tishyaa Sarkar
  • 4.  RE: Project Boundary - PLEASE REMOVE IT
    Posted 09-23-2026 14:21
    We are discussing project boundaries in WM, I would also like to suggest the possibility of importing a DWG/DXF file that is automatically referenced and displayed on the map view in the WM portal.
    This should not be particularly complicated to implement, since the project boundary is defined after selecting the coordinate system in which the project is to be defined. The imported DWG/DXF could then simply be referenced using the same coordinate system and displayed directly on the map. This would make it much easier to define a project boundary that is actually relevant to the project, rather than having to create an unnecessarily large area just to make sure that all relevant information is included
    I would also like to point out that the map service/provider currently used for WM is rather limited compared to alternatives such as Google Maps. Improving the map functionality and visual quality would make the portal considerably more useful, especially when working with project boundaries and other geographic data.
    Jimmy Nordholm
    Support Manager
    SITECH Sweden
  • 5.  RE: Project Boundary - PLEASE REMOVE IT
    Posted 09-23-2026 20:28
    Agree 100% with the complain about the limited map provider selection. On my current site the imagery is at least 4 years old.
    Unacceptable that we still can't use our Propeller or other WMTS layer or upload a GeoTIFF or JPG as background for the web UI map.
    A mate of mine was able to do that with a chatbot in no time for a Trimble Connect Extension, graphical view of points with coordinate database, different icons, monitoring charts, different map backgrounds, design data overlay. What he accomplished in a few weeks of afterhours vibe coding would take those WM developers 20 years. And at least 5 times a week "do we really need this?".
