What the steps of process static data and what the adjustment steps and what the setting that i have to keep it in TBC setting for to get first order control point and for your information i observe phase 1 for 24 hours to get the first solution from knon
Question asked by Faisal Al-Balushi on Mar 21, 2020
Hi how i can prepare the TBC setting for the below project and what the TBC steps for process and adjustment the static data
Project specification :
          • Second order (Horizontal) GNSS Survey General Specifications:
Sl/No.
Specification - General
Static
1
Minimum number of reference stations to control the project
3 NSA first order(Horizontal)
2
Maximum distance between the survey project boundary and network reference control station
70 to 80 km
3
Location of reference network control (relative to center of project) minimum number of “quadrants” not less than
3
4
Minimum percentage of all baselines contained in a loop
100%
5
Direct connection between survey stations which are closer than 20 percent of the distance between those stations traced along existing or new connections (adjacent station rule)
Yes
6
Minimum percentage of repeat independent baseline
5%
7
Minimum number of independent occupations per station
100% (2 times) 10% (3 or more times)
8
Direct connection between inter-visible azimuth pairs
Yes
  • Second order (Horizontal) GNSS Survey Field Specifications:
Sl/No.
Specification - Field
Static
1
Maximum PDOP during station occupation
7 (75% of times)
2
Minimum observation time on station
1 hours
3
Minimum number of satellites observed simultaneously at all station
6 (75% of times)
4
Maximum epoch interval for data sampling
15 seconds
5
Minimum time between repeat station observations
45 minutes
6
Minimum number of primary control stations
=>3
7
Minimum length of observations
=>24 hours
8
Antenna height measurements in meters at beginning and end of each session (2)
Yes
9
Minimum satellite mask angle above the horizon (3)
10⁰
  • Second order (Horizontal) GNSS Survey Office Specifications:
Sl/No.
Specification - Office
Static
1
Fixed integer solution required for all baselines
Yes
2
Ephemeris
Broadcast
3
Initial position: maximum 3D position error for the initial station in any baseline solution ( Navigation position)
20 meters
4
Loop closure analyses, maximum number of baseline peer loop
8
5
Maximum loop length
75 km
6
Maximum misclosure peer loop , in terms of loop length
50 ppm
7
Maximum misclosure peer loop in any one component (x,y,z) not to exceed
8 cm
8
Repeat baseline length not to exceed
50 kilometers
9
Repeat baseline difference in any one component (x,y,z) not to exceed
50 ppm
10
Maximum length  misclosure allowed for a baseline in a properly –weighted, least squares network adjustement
50 ppm
11
Maximum allowable residual in any one component (x,y,z) in properly-weighted, least squares adjustment
8 cm
