Help in creating a job in Access
Question asked by GUY BIEN on Apr 13, 2020
Latest reply on Apr 20, 2020 by GUY BIEN
I am struggling with the simplest way to create a new job within Access so that it is on State Plane Coordinates and has a record map Basis of Bearings.
The area I am working in has no reliable NGS benchmarks, so I need to do an OPUS solution on a point and I have recovered several monuments of record.  I would like to be able to set up the base station on the point to record the OPUS data, measure the found monuments, rotate them to a Basis of Bearings so that I can produce search coordinates for the recovery of other monuments and conduct a topographic survey of the property.  Ideally, I would like to do this all in one shot.  Then be able to take the data back to the office and post process.
Does anyone have a good workflow solution to this process?  I am relatively new to the Trimble software.
Software:  Access 2017.23 and TBC 5.20.
