Importing PDF intermittent display issue.
Question asked by Richard Tyndall on Jul 8, 2020
Latest reply on Jul 23, 2020 by Richard Tyndall
At times there are issues with getting a newly imported pdf to display. Usually, switching the display style to my usual "dimmed" style will make it appear. If that doesn't work, invoking the "Georef Vector PDF" command will make it appear. However, there are occasions where that doesn't even work. As you can see in the clips below, the pdf is there as witnessed by the vector snap under the cursor, however, as you can also see, the pdf is not visible. Please advise.
Once (and if) the pdf does initially display and is Georeferenced, the pdf usually displays as expected.
This issue is quite frustrating as it is intermittent and I am unable to put my finger on what is different to cause the issue.
Yes my display drivers are up to date.
