UAV Ground Control: EPSG not output in export **resolved**
Question asked by jason HINSLEY on Sep 12, 2020
Latest reply on Sep 21, 2020 by Mark Kellaway
I'm a new Trimble Catalyst user, so this may well be something I am doing wrong.
I'm based in the UK using Catalyst DA1 with UAV Ground Control to collect GCP's.
I have been testing out the DA1, in free mode.
Regardless of GNSS configuration in TMM, when points are collected in UAV GC, the export file does not have a value in the 'EPSG Code' field.
AntennaHeight(m), MSLHeight(m) and MSLHeightAtGround(m) are also empty.
I have tried GNSS correction set to Auto and also set a specific frame (ETRF2000 R05), with the same result.
Is this correct?
In was expecting an EPSG code to be output, from the information given in this article:
Defining a reference datum
Thanks
Jason
EDIT: I tried again today using the precision subscription and EPSG code is output to the file, so I guess it was due to using the 'Catalyst Free' subscription.
