Average cut between 2 surfaces
Question asked by Lasse Hanberg on Nov 5, 2020
Latest reply on Nov 13, 2020 by Wayne Welshans
Hi
So I'm trying to calculate the average Cut-value between two surfaces, and was hoping it would be possible to grab it from a report, possibly based on a Cut/Fill Map.
Currently what I've come up with is to use the macro SurfaceToGrid, enable only the "Compute elevations differences", select the two surfaces, put in a small grid and then export to a XYZ-file.
Import this into a spreadsheet and average out the cut-values.
Decent workflow, but was hoping for something a bit more automated that would generate an actual report.
Optimal if the value would just be part of the EarthworkReport, that already show the maximum and minimum cut/fill values.
