Wayne Welshans
Explode corridor surface with line COLORS
Discussion created by Wayne Welshans on Nov 18, 2020
Latest reply on Nov 18, 2020 by Marian Plucinski
The process of recoloring linework generated after exploding a corridor surface is very tedious, repetitive, and time consuming; which is the perfect recipe for a new command.  I don't really care how it accomplishes it, but it should really be possible somehow to assign a color to each node.  Here are some suggestions for accomplishing that:
1) In the corridor template editor where the user enters a name there could also be an option there to select a color.  For example I name a node EOP, then choose color magenta.  When the corridor surface is exploded, there is a linestring named EOP and its color is magenta.
2) Add a whole new "Node Manager" where the user could choose to leave this blank and have the software continue working exactly the same way it does now, or a user could setup various nodes defined by their name and have properties assigned to them that may not only be color but include lineweight, linestyle, layer, etc., etc.  Then in the corridor template editor when a node name is selected from the drop down the associated properties are tagged in the background and when the corridor surface is exploded the generated linework drops onto the assigned layers with all the assigned properties.
3) The existing "Manage Template Node Names" command could probably have extended functionality added to it to get something similar to #2.
