ROBOTIC TARGET HEIGHTS -
Question asked by Mike Trenor on Jun 26, 2016
Latest reply on Aug 11, 2016 by Mike Trenor
Can anyone help with target heights on Access Version 2016.02?
I'm using an S6 robot with the old 360 prism and also the new AT360 target and my Trimble telescopic prism pole is graduated to the top of the pole. So I set up my targets on the TSC3 and define the height to "Bottom notch". Two funny things happen:
1. The "Target height (true)" is not constant, but varies with the target height you key in. (on my TSC 3, for a 0.30m height the offset is 0.144m and for a 3,5m height the offset is 0.157m)
2. The actual constant vertical offset (from base to centre) of both the older 360 prism and the new AT360 target is actually 0.135m
Is this a bug in Access, and/or is there somewhere you can key in your own vertical offset for these targets?
