Feature Code Processing - 2D Linework
Question asked by jspears@usmsurveying.com on Aug 24, 2016
Latest reply on Sep 16, 2018 by Barney Brotherhood
When processing feature codes in TBC, is there an option to turn certain line strings to generate as 2D polylines?
Our current work flow is to process feature codes in TBC, and then export the line work out as a dwg. We then insert the exported dwg into our working drawing. The problem we have is that 3D polylines in autocad do not show the proper linetype - they can only be displayed as continuous. This is not a problem for most line strings, since we need the 3D polylines so that they can be added as breaklines in surfaces, but for fences/utility/building lines etc., it is kind of a pain. Is there a way to change this in TBC?
Thanks for your time.
Jack
