Invisible lines/objects
Question asked by martin@l3ab.se on Dec 16, 2016
bug business center - hce
Multilines and other objects appear invisible and are not selectable in the plan view.
I can select them in the 3D (though for some reason I can not zoom in close enough for them to not appear as a point) and then select edit, and switch to plan view (see attached picture). The objects are then still selected and I can manipulate them. The object in itself is still not visible or selectable and the only visible parts are the current segment markings.
From the picture given, if do a drag select nothing is selected and it is not possible to select anything in the plan view.
Why is this happening and can it be easily fixed?
