problems with project
Question asked by kbeczkowski@gmail.com on Feb 27, 2017
I have a problem, when I open an existing project or when importing data appears in the following dialog box
Below the log. re-installing and cleaning cleaner doesn't help.
I have windows 10. What can I do ???
Exception Count: 1
Exception Source: Trimble.Vce.Core
Exception Type: System.Runtime.InteropServices.COMException
Exception Message: Wyjątek od HRESULT: 0x8111001F
Exception Target Site: a
---- Stack Trace ----
.x.a(String A_0, Boolean A_1)
Trimble.Vce.Core.DLL : N 00963
Trimble.Vce.Core.Projects.Open(String fileName, Boolean exclusiveAccess, Boolean raiseProjectLoadedEvent)
Trimble.Vce.Core.DLL : N 00260
Trimble.Vce.UI.UIManager.UIProject.OpenWithReadOnlyDeniedRetry(String path)
Trimble.Vce.UI.UIManager.DLL : N 00058
Trimble.Vce.UI.UIManager.UIProject.ErrorReportingOpenWrapper(UnprotectedOpen worker, String fileNameAndPath, Exception& exception)
Trimble.Vce.UI.UIManager.DLL : N 00086
Trimble.Vce.UI.UIManager.UIProject.OpenProjectEx(TrimbleOffice Office, String FileName)
Trimble.Vce.UI.UIManager.DLL : N 01031
Trimble.Vce.UI.BaseCommands.FileOpen.Execute(Object[] Parameters)
Trimble.Vce.UI.BaseCommands.DLL : N 02092
Trimble.Vce.UI.UIManager.CommandProcessor.ExecuteCommand(String Command, Boolean ShowInRecentCommands, Boolean CommandLine, Object[] Params)
Trimble.Vce.UI.UIManager.DLL : N 01397
Date and Time: 2017-02-27 18:40:25
Machine Name: BYQ
IP Address: fe80::24a7:68c3:9c68:a46c%3, fe80::30c7:1308:3f57:ff9b%14, 192.168.0.100, 2001:0:34a9:ece7:30c7:1308:3f57:ff9b,
Current User: byq\byqu
Application Domain: TrimbleBusinessCenter.exe
Thread Name: Office UI Thread
---- Assemblies in AppDomain ----
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: TrimbleBusinessCenter, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: Trimble.Vce.Interfaces, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Interfaces.DLL
Assembly Full Name: Trimble.Vce.UI.Controls, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name: Trimble.Vce.UI.UIManager, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name: Infragistics4.Win.UltraWinToolbars.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v15.2.DLL
Assembly Full Name: Trimble.DiskIO, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.DiskIO.DLL
Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name: Trimble.WinCE, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.WinCE.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name: Trimble.Vce.Core, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Core.DLL
Assembly Full Name: TrimbleBusinessCenter.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/TrimbleBusinessCenter.resources.DLL
Assembly Full Name: Trimble.Vce.DeviceIo, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
Assembly Full Name: System.IO.Compression.FileSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
Assembly Full Name: Trimble.Vce.License, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.License.DLL
Assembly Full Name: Infragistics4.Win.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.v15.2.DLL
Assembly Full Name: Infragistics4.Shared.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Shared.v15.2.DLL
Assembly Full Name: UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Assembly Full Name: Gibraltar.Agent, Version=3.0.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Gibraltar.Agent.DLL
Assembly Full Name: Trimble.Vce.UI.UIManager.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.UIManager.resources.DLL
Assembly Full Name: Infragistics4.Win.Misc.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v15.2.DLL
Assembly Full Name: hasp_net_windows, Version=5.11.1.23192, Culture=neutral, PublicKeyToken=56120be447701319
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/hasp_net_windows.DLL
Assembly Full Name: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Assembly Full Name: Trimble.Vce.UI.Client, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
Assembly Full Name: Infragistics4.Win.UltraWinDock.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v15.2.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabbedMdi.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v15.2.DLL
Assembly Full Name: Trimble.Vce.Coordinates, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Coordinates.DLL
Assembly Full Name: Trimble.Vce.Geometry, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Geometry.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Full Name: Infragistics4.Win.UltraWinStatusBar.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v15.2.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
Assembly Full Name: Infragistics4.Win.UltraWinExplorerBar.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v15.2.DLL
Assembly Full Name: System.Windows.Forms.resources, Version=4.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll
Assembly Full Name: Trimble.Vce.UI.Client.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.Client.resources.DLL
Assembly Full Name: mscorlib.resources, Version=4.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/mscorlib.resources.dll
Assembly Full Name: Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Assembly Full Name: UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Assembly Full Name: Trimble.Vce.UI.Controls.PropertyGrid, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
Assembly Full Name: Infragistics4.Win.UltraWinGrid.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v15.2.DLL
Assembly Full Name: System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Assembly Full Name: System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Assembly Full Name: Trimble.Vce.Persistence, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Persistence.DLL
Assembly Full Name: Trimble.Vce.Collections, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Collections.DLL
Assembly Full Name: Trimble.Vce.ForeignCad, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.ForeignCad.DLL
Assembly Full Name: Trimble.Vce.Data.RawData, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.RawData.DLL
Assembly Full Name: Trimble.Vce.Data, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.DLL
Assembly Full Name: Trimble.Vce.ForeignCad.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.ForeignCad.resources.DLL
Assembly Full Name: Trimble.Vce.Core.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Core.resources.DLL
Assembly Full Name: nunit.framework, Version=2.6.3.13283, Culture=neutral, PublicKeyToken=96d09a1eb7f44a77
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/nunit.framework.DLL
Assembly Full Name: Trimble.Core.Gdtic, Version=4.60.82.3, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Core.Gdtic.DLL
Assembly Full Name: Trimble.Geodetic.Math, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Geodetic.Math.DLL
Assembly Full Name: Trimble.Core.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
Assembly Full Name: Trimble.Vce.Coordinates.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Coordinates.resources.DLL
Assembly Full Name: Trimble.Geodetic.Optical, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Geodetic.Optical.DLL
Assembly Full Name: Trimble.Properties, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Properties.DLL
Assembly Full Name: Trimble.Vce.Data.RawData.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.RawData.resources.DLL
Assembly Full Name: System.Xml.resources, Version=4.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Xml.resources.dll
Assembly Full Name: Trimble.Geodetic.Optical.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Geodetic.Optical.resources.DLL
Assembly Full Name: Trimble.Vce.Reports, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Reports.DLL
Assembly Full Name: Trimble.Geodetic.Reductions, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Geodetic.Reductions.DLL
Assembly Full Name: Trimble.Vce.Data.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.resources.DLL
Assembly Full Name: Trimble.Vce.Alignment, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Alignment.DLL
Assembly Full Name: Trimble.Vce.Data.Construction, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.Construction.DLL
Assembly Full Name: Trimble.Vce.Gem, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Gem.DLL
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Assembly Full Name: System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
Assembly Full Name: Trimble.Vce.Alignment.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Alignment.resources.DLL
Assembly Full Name: Trimble.Vce.Gem.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Gem.resources.DLL
Assembly Full Name: System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Assembly Full Name: Trimble.Vce.Data.GNSSData, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.GNSSData.DLL
Assembly Full Name: Trimble.Vce.Data.Results, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.Results.DLL
Assembly Full Name: Trimble.Vce.Data.GNSSData.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.GNSSData.resources.DLL
Assembly Full Name: Trimble.Vce.Data.Results.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.Results.resources.DLL
Assembly Full Name: Trimble.Vce.Data.Construction.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.Construction.resources.DLL
Assembly Full Name: Trimble.Vce.Data.Scanning, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.Scanning.DLL
Assembly Full Name: Sde.NET, Version=2.4.45.51843, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Sde.NET.DLL
Assembly Full Name: WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name: PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name: Trimble.Vce.Data.Scanning.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.Scanning.resources.DLL
Assembly Full Name: Trimble.Vce.Data.SCS, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.DLL
Assembly Full Name: Trimble.Vce.Data.SCS.Utilities, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.Utilities.DLL
Assembly Full Name: NUnit-retry, Version=1.0.5596.25209, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/NUnit-retry.DLL
Assembly Full Name: Trimble.Vce.Features, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Features.DLL
Assembly Full Name: Trimble.Vce.FeatureDefinitions, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.FeatureDefinitions.DLL
Assembly Full Name: Trimble.Vce.Features.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Features.resources.DLL
Assembly Full Name: Trimble.Vis.Model, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vis.Model.DLL
Assembly Full Name: Trimble.Vce.SyncServiceIntegration, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.SyncServiceIntegration.DLL
Assembly Full Name: Trimble.Vce.Data.MobileMapping, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.MobileMapping.DLL
Assembly Full Name: Trimble.Vce.Data.MobileMapping.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Data.MobileMapping.resources.DLL
Assembly Full Name: Trimble.Vce.Epm, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
Assembly Full Name: Trimble.Vce.GraphicsEngine2D, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name: Trimble.Vce.ReportEngine, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
Assembly Full Name: Microsoft.ReportViewer.WinForms, Version=11.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.ReportViewer.WinForms/11.0.0.0__89845dcd8080cc91/Microsoft.ReportViewer.WinForms.dll
Assembly Full Name: Trimble.Vce.Data.UASMaster, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
Assembly Full Name: Trimble.Vce.ProductRegistration, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.ProductRegistration.DLL
Assembly Full Name: Trimble.Vce.Units, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Units.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTree.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v15.2.DLL
Assembly Full Name: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name: Trimble.Vce.UI.PPCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
Assembly Full Name: Trimble.Vce.ViewModel, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
Assembly Full Name: Trimble.Vce.UI.Hoops, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
Assembly Full Name: Trimble.Vce.Services.Construction, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
Assembly Full Name: Trimble.Vis.Tools, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionReports, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
Assembly Full Name: System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name: CefSharp, Version=45.0.0.0, Culture=neutral, PublicKeyToken=40c4b6fc221f4138
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/CefSharp.DLL
Assembly Full Name: Infragistics4.Win.UltraWinListView.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v15.2.DLL
Assembly Full Name: Trimble.Vce.Functions.SCS, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
Assembly Full Name: Infragistics4.Win.UltraWinChart.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v15.2.DLL
Assembly Full Name: Trimble.Vce.Hoops, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
Assembly Full Name: Trimble.Vce.UI.Construction, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
Assembly Full Name: Trimble.Vce.UI.ScanningCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
Assembly Full Name: Trimble.Vce.UI.ScsCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
Assembly Full Name: Trimble.SCS_WorkOrder, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
Assembly Full Name: Infragistics4.Win.UltraWinEditors.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v15.2.DLL
Assembly Full Name: Trimble.Vce.UI.Features, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
Assembly Full Name: DataInteroperabilityComponent, Version=1.3.0.0, Culture=neutral, PublicKeyToken=3c2e0c2def562052
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
Assembly Full Name: Trimble.Vce.UI.Wrapper, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
Assembly Full Name: Trimble.Vce.UI.GNSS, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
Assembly Full Name: Trimble.Vce.UI.SCS, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
Assembly Full Name: Trimble.Vce.UI.Controls.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.Controls.resources.DLL
Assembly Full Name: Trimble.Vce.UI.MobileMappingCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.DLL
Assembly Full Name: System.Runtime.Serialization.Formatters.Soap, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
Assembly Full Name: Infragistics4.Win.SupportDialogs.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v15.2.DLL
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
Assembly Full Name: Trimble.Vce.UI.Reports, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
Assembly Full Name: Trimble.Vis.PdfImporter, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
Assembly Full Name: Trimble.Vce.Data.Import, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
Assembly Full Name: Trimble.Core.CSDUI.MVP, Version=3.1.2.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
Assembly Full Name: Trimble.Vce.Data.REB, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
Assembly Full Name: Trimble.Vce.Data.ComputationEngine2, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.DLL
Assembly Full Name: Trimble.Vce.UI.INetDownload, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
Assembly Full Name: Trimble.Vce.UI.CoreCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
Assembly Full Name: Trimble.Vis.UI.TccCommands, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
Assembly Full Name: Trimble.Vis.UI.Core, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
Assembly Full Name: Takeoff.UI, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Takeoff.UI.DLL
Assembly Full Name: Takeoff.Reports, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Takeoff.Reports.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.BaseCommands.resources.DLL
Assembly Full Name: Trimble.Vce.UI.PPCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.PPCommands.resources.DLL
Assembly Full Name: Trimble.Vce.UI.INetDownload.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.INetDownload.resources.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.ConstructionCommands.resources.DLL
Assembly Full Name: Trimble.Vce.Services.Tcc, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
Assembly Full Name: Trimble.Vce.Services.Construction.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Services.Construction.resources.DLL
Assembly Full Name: System.resources, Version=4.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.resources.dll
Assembly Full Name: Trimble.Vce.Services.Tcc.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Services.Tcc.resources.DLL
Assembly Full Name: Trimble.Vce.UI.ScsCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.ScsCommands.resources.DLL
Assembly Full Name: Trimble.Vce.UI.CoreCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.CoreCommands.resources.DLL
Assembly Full Name: Trimble.Vce.UI.Features.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.Features.resources.DLL
Assembly Full Name: Trimble.Vis.UI.TccCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vis.UI.TccCommands.resources.DLL
Assembly Full Name: Trimble.Vce.UI.ScanningCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.ScanningCommands.resources.DLL
Assembly Full Name: Takeoff.UI.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Takeoff.UI.resources.DLL
Assembly Full Name: Trimble.Vce.UI.MobileMappingCommands.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.MobileMappingCommands.resources.DLL
Assembly Full Name: Trimble.Vce.MobileMapping, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
Assembly Full Name: Trimble.Vce.Services.WeoGeo, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
Assembly Full Name: Trimble.Vce.Services.Bentley, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
Assembly Full Name: Trimble.Vce.Services.Insphere, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Services.Insphere.DLL
Assembly Full Name: Vianova.Core, Version=20.0.7806.0, Culture=neutral, PublicKeyToken=2fb6462fcbff4df7
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Vianova.Core.DLL
Assembly Full Name: QuadriBIMClientAPIModel, Version=1.0.6078.17269, Culture=neutral, PublicKeyToken=2fb6462fcbff4df7
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/QuadriBIMClientAPIModel.DLL
Assembly Full Name: System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Assembly Full Name: System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
Assembly Full Name: Newtonsoft.Json, Version=9.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Newtonsoft.Json.DLL
Assembly Full Name: Trimble.Identity, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Identity.DLL
Assembly Full Name: VianovaWebServices, Version=20.0.7806.0, Culture=neutral, PublicKeyToken=2fb6462fcbff4df7
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/VianovaWebServices.DLL
Assembly Full Name: System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Assembly Full Name: Trimble.IS.IPPxGate, Version=4.3.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
Assembly Full Name: SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Assembly Full Name: System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Assembly Full Name: System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
Assembly Full Name: System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Assembly Full Name: System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Full Name: Infragistics4.Win.UltraWinSchedule.v15.2, Version=15.2.20152.2052, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v15.2.DLL
Assembly Full Name: Interop.PortableDeviceApiLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Interop.PortableDeviceApiLib.DLL
Assembly Full Name: Trimble.Vce.DeviceIo.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.DeviceIo.resources.DLL
Assembly Full Name: Trimble.Vce.Data.ScJob, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
Assembly Full Name: Trimble.Vce.Data.GeneralSurvey, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
Assembly Full Name: Trimble.Vce.Data.FieldBookJob, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
Assembly Full Name: Trimble.Vce.Data.MercuryJob, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDS, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
Assembly Full Name: Trimble.Vce.Data.SpJob, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
Assembly Full Name: Trimble.Vce.Data.GeoNav, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
Assembly Full Name: Trimble.Vce.Data.AshtechJob, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
Assembly Full Name: Microsoft.mshtml, Version=7.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
Assembly Full Name: Trimble.Vce.Units.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Units.resources.DLL
Assembly Full Name: Trimble.Vce.Interfaces.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.Interfaces.resources.DLL
Assembly Full Name: Trimble.Vce.SurveyCAD, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.SurveyCAD.DLL
Assembly Full Name: System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Assembly Full Name: Trimble.Vce.InSphere.Reports, Version=25.0.6197.32161, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionReports.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.ConstructionReports.resources.DLL
Assembly Full Name: Trimble.Vce.UI.GNSS.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.GNSS.resources.DLL
Assembly Full Name: Trimble.Vce.UI.Reports.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Trimble.Vce.UI.Reports.resources.DLL
Assembly Full Name: Takeoff.Reports.resources, Version=25.0.6197.32161, Culture=pl, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///G:/Trimble/Trimble Business Center/pl/Takeoff.Reports.resources.DLL
