I'm trying to break a large point cloud into smaller groups so that multiple people can work on a job simultaneously. However, when I export a portion of my point cloud as las (us survey feet) the resulting file always comes back in to TBC shifted-- I suspect it is shifted to international feet. I get the same results using other formats also. What could I be doing wrong?
I see this post is from February. Did you find an answer? How much is your shift? There's a setting when exporting an LAS to scale it to ground by default. If your control was set using GPS and is georeferenced, chances are you should export using grid.
