Hi guys,
Does anyone know how to take a screenshot of Trimble Access running on a Trimble Slate Controler?
Where are those screenshot files saved?
Thanks for the help!
Jaka
Hi guys,
Jaka
This works only if you have Access running…
The TSC3 does the screen capture when you hit control and S. It only works when you are inside of Trimble Access. It then saves it under the folder of the users name.
To answer a question I just got in the comments…
The screen capture is stored as”ScreenDump000x” in the username folder in Trimble Data, you can rename it there, but I don’t think you can associate it with a point.
Marek
Hi Marek,
I'm using Slate controler, and there is no direct printscreen functions
that I know of.
I used the MyMobiler program to connect it to PC and took a screenshot
there.
Regards,
Jaka
Jaka Gorišek
Sales engineer
M +386 41 256 296 | T +386 8 200 16 63 | jaka.gorisek@gdi.net
<neven.bahtijarevic@gdi.net> | www.gdi.net
Creating Efficiencies. Stimulating Growth.
On Thu, Mar 1, 2018 at 9:21 PM, marek.mazur@cima.ca <trimble@jiveon.com>
Hi Jaka,
The Trimble Slate Controller doesn’t have screen snap or print screen option. However, there is a small utility called MyMobiler (http://mymobiler.com/windowsmobile.html) which can be installed on the Slate and a PC. Then, connect the Slate via USB cable to the PC and you can bring the Slate screen on the PC via MyMobiler, afterwards, take screen snaps and control the slate using the mouse.
Abdul
