Hi all,
I would like to report the following problem with construction display in Trimble Connect web. Fo further details please have a look at picture 02.png. The problem is caused by large coordinates. The display is not ok, even if I use Positioning funkcion. The only possible way how to solve it is to change the position of the construction in the original file, which is not always possible.
thx
Pavel
Hi Pavel,
Thank you for reporting this. We are working to fix this issue.
If you need to work with such models, please try Trimble Connect Desktop. Large coordinates should work there.
Best regards,
Marko Myllymaa
