Tekla Structures Connector will not connect to Trimble Connect. Do you need a Trimble Connect lisense for Tekla Structures Connector to work? When trying to login to Trimble Connector(In Tekla) with Trimble Identity it says
"An error has occurred while executing the operation. Check your internet connection and try again"
Tekla Structures are logged into Trimble identity and Model Sharing is working.
Using Tekla Structures 2017i, and Service Pack 4.
Hi Daniel,
Please try the following workaround if you still experiencing the issue.
1. Open the config file that you can find from the following path using text editor
Config file - C:\Program Files\Tekla Structures\<version>\nt\bin\applications\Tekla\Model\TrimbleConnector
2. Replace the following text in this role ...<add key="ServiceUri".... with
<add key="ServiceUri" value="https://app.connect.trimble.com/tc/api/2.0/" />
3. Save the config file.
4. Restart Tekla Structure software.
5. Login to Trimble Connector using Trimble account.
Thanks,
Fern
