Select Elements in TBC Using Existing Polygon
Question asked by Barney Brotherhood on Aug 19, 2018
Latest reply on Aug 23, 2018 by Josh Weckert
Hi. I would like to know if there is a means of selecting elements within a project (points, lines, vectors etc.), using a pre-existing closed polygon/rectangle.
I am trying to select a large number of points from a ground topo, within an existing closed polygon. I understand I can select using the 'Polygon Select' mouse method, but this is not the same; the polygon I have in my project is complex e.g. contains straight edges and curves, and is not easy to trace by hand (not to mention hugely time-consuming).
The screenshot below shows the polygon and the area within which I wish to select.
I've used this same command in older (non-Trimble) sw. Wondering whether this function is either available or in the pipeline?
Many thanks in advance.
Polygon Select Screenshot
