Utility Node Import
Question asked by Logan Whitehead on Aug 30, 2018
Latest reply on Aug 31, 2018 by Alan Sharp
Is there any way to import utility nodes if provided xyz data, or is a manual entry for each node & rim/invert elevation the only way that we can bring this data into the utility network?
We can bring in 3D linework associated with a network from the designer and although we can snap to each xyz location of the node, we must then manually snap to each node in the network and input the rim & invert elevations by hand.
It would be useful to have a way to import an entire network of nodes at known XYZ coordinates (rim elevation, perhaps). We could then re-build the network by 'connecting the nodes' with manual entry of invert elevations and site improvements for each node and pipe run.
