Feature attributes and custom reporting
Question asked by Katie Byron on Sep 12, 2018
Is there a way to separate feature attributes in custom reporting? I have set up a point feature in an fxl library to be able to mark all of the attributes of compaction testing shots (wet density, dry density, probe depth, etc.) and I would like to create a custom report that would separate certain attributes into assigned columns. Is there a way to do this?
So far I have only been able to insert "attribute" while editing the custom report template, but it will add all of the attributes of that point into the particular row/column and won't give me the option to choose which attribute I would like there. I also just need the attribute to have the given data (i.e. 98.2, 2220.9 etc.) and not the name of the attribute as that would ideally be in the column header.
