Bottom of footing model Work flow
Question asked by Britton Lawson on Sep 26, 2018
Latest reply on Oct 2, 2018 by Alan Sharp
Just curious how everyone is creatig their BOF models. Currently we use the track region command to speed up the clean up process of having one continuos footing line as opposed to the join command or drawing a new line and snaping to existing data. For elevation, we are entering in vertical nodes for every step, footing, and column pad in the running footing So for one column pad in the running footing we could be creating eight vertical nodes. which, depending on the design, can be a lot.
So I thought I would throw it out here to see if anyone has a better workflow to speed things up in this area to apply thickness and creat the steps in a streamlined process.
