I have an issue when editting within business centre, just a small QOL basically but every now and then the plan view I'm working on seems to regen badly, all my linework becomes larger and quite distorted I can either close the plan view and open a fresh one or restart the program, both solutions work but was just wondering if anyone else is having this problem at all.
It generally hits when I'm breaking and joining lines. I have attached a couple of screenshots, one with the distortion and one as it is supposed to look.
Thanks for raising this - what you are seeing is a Hoops Graphics issue that we believe that we have now addressed in upcoming releases. Hoops is a Graphics Library that we use to drive the Display in Business Center - HCE. Other leading CAD products like AutoCAD also use Hoops. We have found that occasionally this will happen and the development team believe that they have tweaked the software so that it no longer does this (Never say Never though).
When we release the update product at Dimensions. please let me know if you continue to see this issue - I have not seen that personally for a while now in Testing and Use of Pre Release product.
