Is the ground distance accurate in Trimble access
Question asked by Mitchell Dyck on Dec 18, 2018
Latest reply on Dec 24, 2018 by Mitchell Dyck
I have heard of guys getting their scale factor by measuring a distance with a TS and then measuring it with a Gps and scaling accordingly. Trimble access has it where if you compute an inverse between two points, you can change the distance it shows you from grid or ground. The ground distance you get from there, points measured with gps, is that ground distance an accurate distance or has it just calculated a scale factor and given a predicted ground distance?
