Feature Request - Select utility runs from plan view
Question asked by Patrick L'heureux on Jan 17, 2019
Latest reply on Jan 29, 2019 by Patrick L'heureux
The reason I would like to select utility runs from plan view is because I was fortunate enough to receive a LandXML file from an engineer that had the drainage and sewer and I now what to go through and assign utility runs to their respective reference alignment.
The only and "quickest" way I found to do this is to go:
  1. Project Explorer
  2. Right click on the run and select "Select Members"
  3. visually see where the run is,
    • if you model you drainage in orange as I do, you will need to change the BC from the default orange to something else. This threw me off at first.
  4. Select the run
  5. Change the reference alignment
  6. Repeat until done
This is not awful for a smaller project but it would be an absolute nightmare for a large municipality project with many alignments and potentially hundreds of pipe runs.
