In TBC 5.0 how to you change the pop-up window display properties so that they stack on top of one another rather than layer or appear side by side? Using the hide, floating and auto hide options doesn't appear to fix the issue.
See the unwanted (side by side) view of multiple command windows and the desired view (which only has a single command window open. In previous versions, the command windows opened up on top of one another. I want to see this again please.
Thanks for your help!
Once you are using TBC 5.00 you can click on the small arrow and select Floating. Properties window is unlocked and you can move it. Then you can move it over the Project Explorer and View Filter Manager. Please find below screen snap showing the result.
Cheers Steven
