I have a scanning station with SX10. So, I have the JOB file and the respective folder. The problem is related to station configuration because I forget to give station height in the initial configuration.
In TBC when I import SX10 data, scanning RWCX is not included. After this, I change the height in the properties station but nothing change with the scanning data.
I have tried to import manually the scan data and to recalculate, but it doesn't take the correct position even with the correction in the height.
What can I do? Any thoughts?
Hi Ariel, have you tried updating the station height from the original Trimble Access job?
Rui
