RTK level of confidence
Question asked by Alin Boicu on Feb 3, 2019
Latest reply on Feb 7, 2019 by Richard Selby
Hi everyone !
Does anyone know how long time is it necessary between first RTK fix solution and second RTK fix solution for the same point, in order to be sure the satellites that provide the first and the second fix solution, are mostly different ?
I want to know that because I consider to ask my surveying team, for each new land surveying job, to double check at least two new points, using re-initialization of the receiver, but I would like this double measurement of two points not to be done immediately, but at least at 30-60 minutes from the first measurement, so the number of common satellites between first and second solution to be minimum.
Thank you !!!
