Max Desplanches
getHeading() orientation from Trimble SDK
Discussion created by Max Desplanches on Feb 13, 2019
Latest reply on Feb 21, 2019 by Max Desplanches
Hello everyone,
I am using java SDK with trimble Catalyst.
In listener updatePositionTable, we are using PositionUpdate object with getHeading() method. (orientation from nord pole)
Do you know the accuracy of this value ?
Each update, it goes (without move or rotate trimble) with value:
200°
200°
4° (hum)
3° (again)
200°
200°
170°
what is the best case to have always good degree ? (without skip in code if the difference is too big ... but I will finish with this solution if no one have a solution;) ).
Thanks you,
Max.
