Richard Tyndall
Deleting Objects with Layer Manager open causing system instability
Discussion created by Richard Tyndall on Feb 16, 2019
Latest reply on Feb 21, 2019 by Richard Tyndall
More often than not, when deleting objects with the layer manager open (un-docked), the system hangs, then either the Layer Manager or the Program crashes. This is killing production as a restart of TBC is required to get the program to respond as expected nearly every time I forget to close the Layer Manager having used the Select Layer Members command in the Layer Manager.
I estimate:
System hangs 80%+ of the times delete is called with the Layer Manager open. Of the hangs, Layer Manager crashes 80% of the time and TBC crashes 15% of the time. The 5% that the system returns to operational is very "laggy". A restart of TBC returns the system to normal.
Please advise if there is a log, etc that you need to confirm the issue.
Thank you.
