Buck Lawson
Vertical Wall Creation
Discussion created by Buck Lawson on Feb 21, 2019
Latest reply on Feb 27, 2019 by Alan Sharp
Hi Alan Sharp -
The current model I am building includes an MSE wall where the points are based off of another alignment so I do not have their locations just offsets, stations, and elevations. also, there is an area where the offset increases by 5+ feet so I cannot simply offset the alignment to get the point locations. That aside, I want to create a vertical surface so that I can show the wall on the model.
Is there an easy way that you know of to model a vertical surface like that? I had thought about using the points to create another alignment and then using an offset/elevation command.
Thanks,
-Buck
