Adam Bower
Issues with default selection method
Discussion created by Adam Bower on Mar 2, 2019
Latest reply on Mar 6, 2019 by Adam Bower
I'm  having some issues with how I select certain things in Business Center. An example is if I go to create a linestring, then it is prompts me to pick a coordinate, but instead of giving me the crosshairs that it normally does, it's the small square box which is usually used to select a line or object. I have to then right click and choose "free," then click the point I want as that coordinate. Sometimes exiting business center works, but not always. Sometimes it also glitches where when no command is being asked, and it's on the small box selector, it's asking to snap to every snap point I allow to be selected, when normally it's a crosshair to make a selection box.
Something just seems off unless I changed a setting on accident.
