Saif Bin Darwish
XSection Templates in TBC 5.0
Discussion created by Saif Bin Darwish on Mar 6, 2019
Latest reply on Mar 19, 2019 by Alan Sharp
I am creating Corridor template in TBC V5.0.
With the help of Mr Alan Sharp I have progressed somewhat.
I am looking at a solution for this specific challenge:
Please see attached file "Tie to Surface-1.pdf". I want the Daylight L Point to be at the Second or Last intersection of the Surface - not the first. Is it possible to do that.
When I was using Terramodel, I had this choice in the Properties tab of the "Shape" window. Is there something similar in TBC V5.0?
In the second case, ("Shortage of OGL.pdf" ), Slopes are not represented at all. I suppose this is because the daylight line is beyond the available limits of OGL.  I was expecting one of two things:
a) The OGL segment would extend to  chamfer with the slope line (as in Terramodel) OR
b) The conditional instructions would come into play as in TBC and a slope line to the "Fill Limit" would be drawn at a slope of between the recommended 1:6 and the minimum 1:3.
Both are not happening !!!
Could some one show me a way please.
Thanks.
