Is there a way to move a linestring where you can input the distance you want to move it and then select direction, something similar to the way you offset a line. I think this would have a lot of value for curb line clean up.
The reason I want this as a move is because I do not necessarily want to delete the line if it is part of a surface.
The video demos the need
There is a way using the right click snaps
